Hi All
Can any body tell me what is the best way to route the wires from the indicator on the front wing to the body?
Happy easter Axle
[Edited on 30/3/13 by axle]
I stuck some cable ties under the arches with tiger seal then tie-wrapped the wires along under the arch. Still there at the moment
Just make sure you cover the cables in something tough like spiral wrap, stops the road crap eating into the wires
its worth searching for discussions on putting side repeaters on rear arches for IVA.
Much easier to fit them to the rear arches, I fed the cables through 6mm flexi conduit, and sikaflexed it to the inside of the arch.
Side Repeaters
Thank U all for your inputs.
Cheers axle
