At the moment I've used large choc blocks for setup testing.
These wires are high amp and one is a wire direct from battery to ignition which then shares to Ignition / ACC wires coming from the ignition going to
the CBS fuseboard.
that will be running - headlights, sidelights, indicators, heater/aircon, horn, rad fan, dials, wiper motor and washer jet, brake lights, radio
Wired direct to battery - alternator, fuel pump, ecu, starter motor (only relay off ignition wire (seperate wire) to activate all the engine
requirements in a rear fusebox)
I have wired in the additional fusebox from the MR2 I used and the circuit protector amp there is 50amps on one and 80amps on the other, with overall
protection of 120amps. Now that was for an MR2 with all the gizmo's obviously.
[Edited on 21/2/14 by killerferret666]
I would have thought sidelights ( at least ), horn and emergency flasher, perhaps radio ( but your choice ) shouldn't be via ignition. Reverse
light ? Fog light ?
Fuel pump and ecu direct to battery ?
Originally posted by Macbeast
I would have thought sidelights ( at least ), horn and emergency flasher, perhaps radio ( but your choice ) shouldn't be via ignition. Reverse light ? Fog light ?
Shouldn't the wire go straight from the battery to the fuse box with no breaks/ connectors needed? Why is the wire not just a straight link or am
I missing something
Originally posted by peter030371
Shouldn't the wire go straight from the battery to the fuse box with no breaks/ connectors needed? Why is the wire not just a straight link or am I missing something![]()
One of my many other hobbies is RC modelling. The increasing use of LiPo power in high amp applications for modelling means that there is a plethora
of connectors available for linking batteries and speed controllers and motors.
Google deans connectors or search for XT60 connectors (or something equivalent)
I hope this helps?
Originally posted by carpmart
One of my many other hobbies is RC modelling. The increasing use of LiPo power in high amp applications for modelling means that there is a plethora of connectors available for linking batteries and speed controllers and motors.
I hope this helps?
