starter problem
ali f27 - 4/5/14 at 08:36 AM
Hi starter has developed a problem it engages turns over one time then then disengages with the flywheel and just spins any thoughts
Cheers Ali
britishtrident - 4/5/14 at 09:23 AM
Cheers Ali
What engine & starter type.
If it is an xflo with an inertia 2 bolt starter then it could be caused by the sandwich plate between engine and gear box being omitted when the engine and gearbox were mated up.
ali f27 - 4/5/14 at 09:33 AM
Hi duratec has been fine for about 2 months just started doing it yesterday
JacksAvon - 4/5/14 at 10:45 AM
A poorly fitted starter on my 2lt zetec has chewed a secton of teeth out of the ring gear.
May be worth taking the starter off and looking at the ring gear
