Just a quickie.
when i got my car, I could start it in gear
Then i re-wire it, and now it oly starts in nuetral
Can anyone tell me what needs wiring to what to get it to start in any gear again?
CBR900 (919)
Matt
Is your clutch switch working? Most bikes have a neutral and clutch switch, one or the other is required to be operating to start the engine.
erm, im not sure if there is one, is it part of the engine or located seperate
if its seperate, then it doesnt and never has had one
if its part of the engine, I've not seen it before and havnt found any cables for it
It worked before.
It doesn't work now.
Only re-wired it in between.
Therefore something changed when it was rewired.
You said that you re-wired it.
Hence you should know what has changed.
Why don't you know?
Earth the following wires on the ecu - Green, Green with white trace, light green - job done none of the interlocks will have any effect then
yer, I didnt have a clue what went where before I rewired it, so I just did it as per the drawing for the bike, taking out the bits that were no
longer needed.
Thanks Andy, il give that a go when I get chance, hopefully that will solve it
