ECU controlled Alternator?
40inches - 7/2/15 at 10:24 AM
Can these be used without ECU control?
The 80amp one fitted to the Jag engine is small and light. For the output.
And it's free, which is nice
rusty nuts - 7/2/15 at 12:06 PM
Not sure about Jap alternators but IIRC Ford alternators can be disconnected from the ECU to diagnose alternator faults , know of one on a Transit thats been disconnected for about a year
theprisioner - 7/2/15 at 01:40 PM
They are ECU controlled for the application of sealed batteries with Cadmium (I think) at low temperatures and can be charged at eye watering rates but for a very short time. The Ford ones default to ordinary charging rates when disconnected from ECU.
40inches - 7/2/15 at 04:58 PM
It would appear that you are correct
With the plug disconnected the alternator goes into "limp home" mode and charges at 13.5-14.0 volts. Good times!
Just found this thread: http://www.locostbuilders.co.uk/viewthread.php?tid=169207
[Edited on 7-2-15 by 40inches]
