Seen these on eBay
eBay Item
Not worried about IVA, I do want to pass an MOT, how does dip work on LED,s are they directional like bulbs or just point down more accurately so not
handed?
Cheers Mark
The projector lens will bend light to the required direction. I assume each lens has a purpose on those. Top will be mains, bottom will be heads. 2 on side must be sides or just decorative.
I got a set of 5 3/4" ones from russbost when he started selling them. They're really good though getting them to fit in the Fury bowls took so.E creative thinking. The dip/main by switching on/off LEDs focused in different ways.
They look very similar to what we sell, but ours have the DRL & indicator "Halo" around the outside, hence these are much cheaper -
they are however in Hong Kong & you may get caught for some import duty. His feedback is only 98.8% which is a little low for Ebay
Only other thing I'd be slightly bothered about is that he describes them as "Round Fog Head Light Amber LED Cree Angle Eyes" - if they
are foglights they are NOT headlights, can't be both, they shouldn't be amber unless they have the indicator halo, which they don't
& angel eyes would also imply the halo being there which so far as I can see it isn't - in the technical description it does talk about low
& high beam which would obviously be correct for headlamps - all rather ambiguous??
Russbost, have you got a link to yours?
Do you have 5 3/4", and 7"?
https://furoreproducts.co.uk/led-headlights
Thanks, they look perfect, I after a pair of 7" for my Jeep cj, and a pair of 5 3/4" for my Dodge wc62...
Talk to Oli. member name Obuckle on here, or you can email him thro' the furoreproducts.co.uk website, I'm sure he can sort you out a good
deal.
He has both the 7" with halo type, which have indicators & DRL's as well as dip/main beam or he has the "spider eyes" type
which have just the DRL & dip/main, I do know he's pretty short of stock on the 5 & 3/4", but more are on their way
Cheers Russ
