I've been siting up my 09 cbr1000 engine.
Is there any noises if tvr ignition is on to give me a clue that it's live ?
A relay click etc ?
I take it the big lump of green wires on ring terminals get earthed ??
Yes once you have got power to your loom you will here the throttle position activate
what have you done to your wiring at the moment?
resitiers?
by passing? ect
if you are stuck send me a msg and i'll help as much as i can as there
is wires that need to be isolated
Luckily enough I bought a loo. That had been modified to take a HRC ECU. I also got an American ecu with it. I have got power to it and can get the
fuel pump to prime.
I take it once I have the fuel pump priming that I'm past all immobiliser gubbins and should have spark ??
I tried an old plug in one of the coils but could not see a spark but then put a multimeter across the plug to watch and got a voltage when I turned
the engine over.
