Acewell Wiring
budha - 25/4/20 at 05:10 PM
I had some issues with my old dash so I decides to get an new acewell (6xxx)
Today I tried to wire it and wanted to make a test (only rpm from ecu).
So I connected 12v, switched 12v, ground and the rpm signal from the ECU. But nothing happens. The dash does not even light up. Nothing is happening.
Am I missing something here?
[Edited on 25/4/20 by budha]
tims31 - 27/4/20 at 02:27 PM
What was the issue with the original dash, could that be the same reason why this one is not working?
I have the 7xxx version of an Acewell and there are roughly 20 odd wires to connect for that if I remember but it was simple enough to follow what needed connecting where.
Do you have the wiring daigram.
Wiring diagram here
Russboss should be able to help as he was a dealer for them a while ago and had usually has the answers.
[Edited on 27/4/20 by tims31]
budha - 29/4/20 at 08:29 PM
I contacted Acewell and they said the speedo should only need 12v and ground to light up. Looks like my device is faulty.
For the old: dash by now I could sort out why it was not working.
Thanks!
