Racelogic Dash Lost Communication
Mr.P - 19/9/22 at 03:12 PM
Hi guys
I have a Racelogic dash which is reading off my Omex 600 ECU.
All been working fine, Revs, Temps, Shifts lights etc, just noticed its now not reading anything.
Any common issues to look for. Any advice welcome
nick205 - 21/9/22 at 10:12 AM
1. Is the car still starting and running OK?
If YES then the OMEX 600 ECU must still be working.
If NO then the OMEX 600 ECU must be dead as well as the Racelogic Dash.
2. Is the Racelogic Dash completely dead - no lights at all?
If YES then I'd suspect a power failure to the Racelogic Dash - check power and earth connections.
If NO then I'd suspect a data connection failure between the OMEX 600 ECU and Racelogic Dash - check the cable and connectors (both ends).
Just approaching this from a simple electrical fault finding approach.
Mr.P - 21/9/22 at 03:15 PM
Thanks mate
Car runs fine
Racelogic works, I have my Oil Pressure and Fuel Level sensors all working but no information from the Omex, I`m thinking it's the cable from omex to dash
nick205 - 21/9/22 at 03:32 PM
The cable between OMEX and Dash sounds like the problem.
Do you have a digital multimeter with continuity test so you can check the end to end connections of the cable?
Can you make or get a replacement cable (replacement is probably best)?
[Edited on 22/9/22 by nick205]
