Indicator always on
Benzine - 4/8/05 at 08:00 AM
Recently I did what I thought was impossible. Side lights, dipped and main all work...rear lights, brakes lights work
But as soon as i connect an earth to the indicators they come on straight away. I thought this may be due to the stalk being engaged to indicate left or right but no :S
Is this some kind of common complaint? I know it's probably obvious but can't work it out (using PWS loom btw) and no forum searches turned anything up.
Thanks y'all fo the help
JoelP - 4/8/05 at 08:15 AM
does it still do it if you unplug the stalk switches? Are you using sierra switches with a normal 3 connector flasher relay?
And, is it possible that the hazard lights are on?
does it do it with the ignition off? If so, its a hazard light problem.
[Edited on 4/8/05 by JoelP]
DarrenW - 4/8/05 at 08:28 AM
Wild idea - im no expert. Could the relay be stuck?
Benzine - 4/8/05 at 09:36 AM
Hazard switch is off, just checked But now that I want to test everything it's stopped working completely All other lights still work, just nothing at all with the indicators now :S
mookaloid - 4/8/05 at 09:38 AM
Bummer
Good luck
Mark
Peteff - 4/8/05 at 10:23 AM
Were they flashing or constant ? What colour is the wire from your switch to the Premier wire on the relay, bk/w or bk/gn/w and does it go to terminal 49a which is power out of the relay via the indicator stalk.
Petemate - 4/8/05 at 11:50 AM
Try several rapid operations of the hazard switch - it is responsible for restoring normal indicator ciruits when switched off.
HTH
Petemate
Hellfire - 4/8/05 at 12:03 PM
You've wired it wrong...
Go here : >ME< and click Hazard Circuit, all will become clear.
Benzine - 4/8/05 at 12:42 PM
Sorted. Turns out the wiring was fine but inside the hazard switch itself was messed up meaning it was always turned on even though it looked off
Benzine - 4/8/05 at 01:54 PM
ARGH!!! Electrics will be the death of me. Shortly after my indicators are fixed, everything works. THEN everything went haywire (which i traced to a bad earth)
NOW the brake light it always on Isn't that great! The brakes haven't been properly bled since i replaced a union, could that cause it? Any ideas?
Spanks
JoelP - 4/8/05 at 04:04 PM
thats an easy one! Try removing the wires from the switch (pressure switch i assume?). If it stays on, you've missed out the switch. If it goes off, the switch or the brake pipes are awry.
Benzine - 4/8/05 at 07:43 PM
Thanks, took off the wire to the switch and the lights go out
Before doing the electrics I replaced this switch union as the old one was leaking. I haven't bled the brakes since so could air be trapped around the switch/in the lines and be causing the switch to be always on? When i first connected the switch the lights worked properly but as i used the brakes more and more throughout the day they started to always be on :S
