savage start switch
kev R1 - 8/2/06 at 08:41 PM
can anyone shed any light on how i wire my start switch to light up? it works to start the engine but no light?
Deckman001 - 8/2/06 at 08:44 PM
You can either take a feed from the ilumination circuit, of take a feed from the ign live going to the switch ??
You have u2u as well
[Edited on 8/2/06 by Deckman001]
kev R1 - 8/2/06 at 08:52 PM
yeah cheers mate i know that but want to know which pins to wire it to.
bigrich - 8/2/06 at 08:59 PM
12v in to pin1 12v out to starter solenoid pin2 then ignition live or side lamp feed to one lamp connection and earth the other if no illumination reverse lamp wires as its a diode and only flows one way round hope it makes sense to you
RazMan - 8/2/06 at 09:01 PM
bigrich - 8/2/06 at 09:03 PM
glad the diagram shows my memory is still ok
kev R1 - 8/2/06 at 09:14 PM
thanks guys,kev
flak monkey - 9/2/06 at 03:21 PM
Got my 'Start' switch today. Just had a look in the Farnell catalogue at the actual switch block.
http://uk.farnell.com/jsp/endecaSearch/partDetail.jsp?SKU=1082353&N=401
Its only rated to 6A. I am thinking a relay might be needed??
[Edited on 9/2/06 by flak monkey]
iank - 9/2/06 at 03:24 PM
Are you sure? This page claims 10A which should be fine...
http://www.motor-world.co.uk/kroozin/show_prod.php?prod_id=1380&PHPSESSID=5507910917b24e386799e8e29742dfa5
flak monkey - 9/2/06 at 03:27 PM
I only know what Farnells say. Its definately the right block, and they (Farnell) arent usually wrong. But that is the current rating for AC, which IIRC is actually higher than the DC rating...
No doubt it will work without a relay, however the life of the switch will be seriously lowered.
RazMan - 9/2/06 at 10:13 PM
Definitely do not connect without a relay. It is only a microswitch after all
*edit* Thinking about it again, the switch will only be closing a solenoid which can only be a few amps (less than 6A anyway) so it should be fine.
[Edited on 10-2-06 by RazMan]
DarrenW - 10/2/06 at 10:39 AM
The start switch is fine without relay. Works great on my pinto. Defo rated higher than 6A.
For illumination, i just connected all centre + pins together and to the side light =ve. All -ve centre pins together and to chassis. Very easy and very neat.
If a switch does not illuminate even after correct wiring it could be that the LED has become detached after transit. Easy to open up, push bulb back into holder. Ive had 2 like that. No need to return to supplier.
RazMan - 10/2/06 at 10:50 AM
You can always connect the led to the alternator light so that it lights up when you turn the ignition on and goes out when the engine has started.
flak monkey - 10/2/06 at 03:13 PM
Exactly what I am going to do with mine
I think the contact ratings for the switch are per side (its actually a double microswitch) so across both switches it could take 12A. So I will connect both sides of the switch together. Should be ok I think. The starter relay/solenoid is on 2mm^2 cable on my escort loom. (Which will be running a Pinto eventually).
wilkingj - 10/2/06 at 08:38 PM
Coo Its amazing what you learn on this forum...
I thought a Savage Start was:- Revs to Maximum... then Drop the Clutch
Edit:
I would always use a relay. Just pick up a handful every time you go to a scrap yard, they always come in handy for something or other
[Edited on 10/2/2006 by wilkingj]
flak monkey - 13/2/06 at 04:46 PM
Well here is my solution. For those who cant be bothered to work it out themselves. The colours on your loom may not match mine, but you get the idea...
The numbers in brackets are the cable cross sections. START is the start button...
It should work! If anyone can see a problem with it, then shout...
[Edited on 13/2/06 by flak monkey] Rescued attachment savage start button wiring.jpg
