OMEX 500 Loom colours
richwalker - 7/5/06 at 08:11 PM
Just looking at my loom for my OMEX 500 ecu for a 1.8 zetec which I got second hand from luego (just before they went out of business) and there is one wire that I cannot work out. There is a pink cable which comes from a white wire out of the lamba sensor. It comes out with 2 power cables and a ground. Connected to the lambda sensor are 2 other cables that go to the ecu and one that goes to ground. Any one got any ideas what the other one is? Cheers. Rich.
blockhead_rich - 7/5/06 at 08:40 PM
The manual for the 500 is available to download from the Omex web site, which has got a full wiring diagram in it. I know as I've used it myself.
Rich
richwalker - 7/5/06 at 09:04 PM
Thanks, ill take a look.
richwalker - 7/5/06 at 09:13 PM
problem solved. its for 12v. Thanks again.
