Zetec Alternator Wiring
Chaz - 15/7/06 at 05:34 PM
Just had a look at old threads and I get the idea that all i need is the one blue wire from the premier wiring loom for the light and a thicker red cable to the starter motor. Is that right?
I have B+, D+ and W marked as three connections on my zetec alternator. Which ones do i use for which wire?
Peter M - 15/7/06 at 08:35 PM
B+ this is the alternater output and would normally have a thick brown wire but maybe red in your case. the D+ normally would have a thin wire this is your field wire and this goes to ignition warning light.The W is not used.Not certain of premier colours
Chaz - 16/7/06 at 08:45 AM
Thanks Very Much!
