sierra indicator stalk
davrus - 16/7/06 at 05:10 PM
Hi ya , can any one help me with my indicators and hazzards , i have a sierra stalk , can any one tell me what relay i need and which wires connect to it , also is the relay a 3 pin or 4 pin plug
Many thank
Davrus
richwalker - 16/7/06 at 09:55 PM
im using a 3 pin relay. 2 to the switch and one to ground. From memory i think its pins 49 and 49a on the stalk.
blockhead_rich - 16/7/06 at 10:16 PM
From my own experience, just be careful and find out if your stalks switch either positive or negative as it took me ages to find out why my Luego relays were not working! Ford did both types in their wisdom, I think the estate type are the odd ones (which I had of course).
Should be straight forward from there on in.
Rich
richwalker - 17/7/06 at 08:24 AM
Yep, i had the same problem with the light relays, took ages to sort out, turns out they were switching on negative, a quick rewire and it was sorted.
