Morning All ,
We are nearing the end of the wiring phase - Hooray
Last item is to sort indicators, Hazzards work fine (sierra switch) but indicators are running x2 or x3 speed. We have a light green wire connected to
49a on the switch with dark green wires to L & R indicators. (aftermarket switch) Question is - i am presuming we need a flasher unit relay, What
wires go to what? It live to 30, what about 85 , 86 & 87 etc?
Daz
Fast flashing usually indicates that you have incorrect bulb wattages installed - have you checked they are all 21W with 5W for the repeaters?
[Edited on 16-1-07 by RazMan]
Yep, all present and correct I am afraid
no repeaters atm, just fronts and rears. there are no spare wires for repeaters so I assume they are not the problem.
Daz
[Edited on 16/1/07 by Big Daz]
You might find that putting the repeaters in circuit will slow down the flashing rate a bit as they are designed for 21+21+5 loading - just connect
them in parallel with the main indicators for a test (you also need them for sva & mot). Failing that I would try another flasher relay before
digging around too much.
Originally posted by RazMan
You might find that putting the repeaters in circuit will slow down the flashing rate a bit as they are designed for 21+21+5 loading - just connect them in parallel with the main indicators for a test (you also need them for sva & mot). Failing that I would try another flasher relay before digging around too much.
I might be missing something here but how are you getting anything to work without a flasher relay ?
Have a look in my archive and you will find a pinout diagram for the Sierra switches - maybe that will shed some light on the subject.
Are you using Christmas light bulbs ? If you have no flasher relay what is making them flash, is the switch a special? The flasher relay needs a constant power supply so I doubt it will work if you already have something causing an intermittent current.
The switch we are using is the bottom one off this page. (green handled One)
http://www.vehicle-wiring-products.co.uk/VWPweb2000/switch-2/switch-2.html
It has 3 terminals marked L, R & 49a
The tiger loom has a light green wire from the loom which we have connected to the 49a and the indicators to L & R
I initially presumed it contained a relay but now I dont think so.
The tiger loom has 2 relays in it, Should I presume one of these is the flasher unit then? - maybe replace it to see if that helps?
Otherwise wire in the repeaters and hope that works?
Daz
Unless you have recently been uttering Voodoo incantations you must have a flasher unit in there somewhere - follow the clicking sound The Sierra
hazard switch is normally combined with the indicator stalk so I presume you have modified in some way.
Sounds like the tiger loom diagram needs a closer look.
Pretty sure that switch does not contain a flasher relay so there must be one in the loom. Usually three wire with the terminals numbered 49 (ignition
live in), 49a ( flashing live out to switch) and 31 (earth). If your indicators flash, front and rear the flasher relay must be there somewhere on the
other end of that green wire. Rapid flash means low wattage. A bulb blown or in your case an earth leak or a low wattage bulb. Physically check the
front bulbs especially if you are using motorbike indicators as some come with 8 or 10 watt bulbs as standard.
[Edited on 16/1/07 by Dusty]
Unless you have recently been uttering Voodoo incantations you must have a flasher unit in there somewhere - follow the clicking sound The Sierra hazard switch is normally combined with the indicator stalk so I presume you have modified in some way.
Ok, by wiring in an extra bulb on each side the problem disappears
Presumably this is due to using bike indicators on the front, Does anyone know where i can get higher rated bulbs for the bike indicators which will
still fit - small glass bulb not large car size?
Daz
if you can't find any you can always load it with a resistor
