Any body know where I can find then in 12V configuration?
First time VWP don't have what I am looking for.
RS Latching Relays
Of any use?
I used these guys frequently. The service was superb and some bits I found to be cheaper than VWP.
They have a latching relay.
[Edited on 18/1/07 by Howlor]
Why not make one from a normal relay? Just take the switched output and run it through a 'push to break switch' and back to the relay coil
feed.
[Edited on 18/1/07 by owelly]
Originally posted by owelly
Why not make one from a normal relay? Just take the switched output and run it through a 'push to break switch' and back to the relay coil feed.
Thanks all
Will just order and see what happens.
maplins, here sell one.
And before ye all scream, it is 12 V but only 2 A, you can use it to switch a fatter relay, so all in, cost should come in under £ 6.
assuming you have the space for 2.
