I have done a search but nothing gives me a definate answer........
I have a set of clocks from a 3ltr Capri as I needed a speedo to use with the type 9 box and I wanted a 6cyl tacho to talk to the Alfa V6. That was
the easy bit!
There are three terminals on the back of the tacho. I have deduced from the stuff I found in the search that the one that stands away from the others
is the earth(??). The other two should be the +ve and the pulse from the coil.
Can anyone tell me the real answer??? I don't like the smell of burning wires and I don't want to find another set of clocks because I have
fried these!!
Cheers, Owelly.
[Edited on 30/7/07 by owelly]
I'm thinking brown -ve, black +ve and white signal but thet is just a guess from your photos.
code:
This way I think for next time
Speedy Cables may be able to help with the correct information.
Sorry was a guess.
