Bench Testing CVH Starter
Slater - 5/12/07 at 06:02 PM
Hi
I want to bench test my CVH starter motor. What terminals should I connect to the 12V battery +ve and -ve?
[img][/img]
Ricks-9r - 5/12/07 at 06:13 PM
A+ ,
B + trigger ,
C -
SeaBass - 5/12/07 at 06:14 PM
If my logic is correct;
A = Main 12V feed from battery (High Current)
B = Solenoid 12V (Lower Current from Ignition Switch)
C = Solenoid out to motor
Casing = Earth
Slater - 5/12/07 at 06:31 PM
Thanks. I'll try it once the kids are in bed.
Peteff - 5/12/07 at 08:14 PM
Clamp or bolt the negative earth to the mounting flange and touch the positive to C just to spin it over. Clamp it in something while you do it.
02GF74 - 10/12/07 at 02:06 PM
Originally posted by Ricks-9r
A+ ,
B + trigger ,
C -
Does C refer to contact on the solenoid? If so, then that is not connected to -.
Nothing is connected to C since this should be wired to the starter motor.
The negative - of battery goes to starter body.
To test solenoid:
+ to B, - to motor body
To test motor
+ to C, - to body
To test motor and solenoid
+ to A, - to body, touch B with + and solenoid should close causing motor to spin.
Id suggest you put your foot on the motor as I expcet the torqye reaction would casue it to jump, then gain, maybe not but you will get some nice fat
sparks
