I'm just trying to figure out exactly what's what with my loom and I have the full workshop manual with wiring diagram. Some of the colours
just aren't quite right so I've checked each version (diff. countries) but none seem to match quite right.
Is it possible Kwaki would use slightly diff wire colours if they were caught short or do we think I might have the wrong loom (like a newer year for
example)????
[Edited on 23/6/08 by eznfrank]
i dont think kwak would use the wrong wire
try a later loom diagram or failing that on the loom somewhere should be a white label with a seriel number on it
email kawasaki and they will tell you which loom you have
HTH
The latter loom has differant plugs for the ecu.
Lots of other things aswell.
