LHD Zetec Haynes Roadster
Blackhole - 5/6/13 at 02:13 PM
Hey, guys!
I'm in process of planning a build. This is how a see it right now:
- Haynes Roadster chassis (stiil looking for a final plan of an LHD one)
- Silvertop Zetec 1.8 on bike carbs + Megasquirt/jolt
- MT75 gearbox
- Black finish =))
Right now I'm looking for a final design for an LHD chassis to fit a Zetec and MT75 gearbox, and I need as much clearance under the engine as possible, cause the roads here are just terrible.
So if anybody has some drawings I could transfer into SolidWorks I'd be extremely thankful =)
Myke 2463 - 5/6/13 at 02:45 PM
This might help and welcome. Check http://www.haynes.co.uk/forums/index.php
http://vouchtroadster.blogspot.se/ or this http://locost.lt/viewtopic.php?f=2&t=14
Good Luck.
snapper - 5/6/13 at 03:18 PM
I think a steel CVH sump fits, this you can shorten for more clearance
Also 15" wheels will give a little more height
Blackhole - 5/6/13 at 03:32 PM
Myke 2463
Thanks for those links, I've already found lots of interesting stuff there =)
snapper
I've done some research on the sumps and I'll definitely need to shorten one (or find somebody to shorten it for me, but I hope I'll get my welding skills good enough till then =) Just wanted to find if there are anything I might do with the chassis to help
Blackhole - 6/6/13 at 12:04 PM
Found this picture in some Lithuanian build, why did he have to cut a piece out, I don't think that will be good for chassis integrity
