As i intend my MX5 based roadster as a track car, i'm interested in the doing the coolant reroute recommended for hard working MX5 engines.
Plus i'm not convinced the cooling system is working that well as it came to me, and rather than try and sort it, i'm planning the
reroute.
there are kits available bu they are expensive and https://coolant-reroute.com/index.html explains very well what is required.
I was wondering do the parts listed work for Haynes roadster with polo radiator as well does anyone know ?
Plus i'm not convinced the cooling system is working that well as it came to me, and rather than try and sort it, i'm planning the reroute.
I bought the alloy thermostat and blanking plate for the top of the old thermostat housing housing from Skid Nation, then made up my own pipes from the rear of the head to the radiator from of 32mm alloy & silicone pipes.
The pipe from the new thermostat housing at the rear of the head just attaches to the radiator, where the old pipe from the front thermostat housing would have went.
Depending on what you have planned you can either blank off the old thermostat housing or remove it completely and fit a 31mm core plug into the head.
If you call Skid Nation they will sell you the specific parts that you require, I have now removed the original thermostat housing and fitted a core plug into the head. If you send me your email address i can send you some pics over.
thanks - if i can work out how to, i'll send you my email address. Pictures would be useful.
What do you use for a temp gauge and where is the sender. I have installed a separate temp gauge and sender but its outside the thermostat loop at the
moment but only temporary.
How do you activate the fan, standard ecu driven. I was aiming for stand alone switch independant of ecu as i plan an ecu upgrade later.
What do you use for a temp gauge and where is the sender. I have installed a separate temp gauge and sender but its outside the thermostat loop at the moment but only temporary.
I’m not sure if this link will work, if it does there’s a few pics of my engine bay.
https://www.dropbox.com/sh/0ebjtgzyew6wkwb/AAApibZUYP19TS-ToNcdcBNaa?dl=0
i've got the spacer block etc from skid nation.
I opted for the core plug rather than the thermostat blanking plate, but it looks as if you need to remove the timing belt and cams (?) to get the
thermostat housing out. Is it bolted in ?
Where is the route for the water that heats the manifold and throttle body. The small hose comes off the thermostat at the front, routes to the TB,
then to the manifold but i can't see a return. Is it via the manifold back into the block somewhere you can't see ? in which case i need to
blank that off some how or water will come out of there ?
I opted for the core plug rather than the thermostat blanking plate, but it looks as if you need to remove the timing belt and cams (?) to get the thermostat housing out. Is it bolted in ?
Where is the route for the water that heats the manifold and throttle body. The small hose comes off the thermostat at the front, routes to the TB, then to the manifold but i can't see a return. Is it via the manifold back into the block somewhere you can't see ? in which case i need to blank that off some how or water will come out of there ?
i think removing the cam belt etc can wait for another day - see how i feel tomorrow. i have the core plug, but need to make a blanking plate if i go that route so its swings and roundabouts.
The manifold throttle body and oil filter housing are all fed in tandem from the back of the engine right by where your new return is going to be. If you are deleting the front neck for a core plug then just tap in a fitting anywhere into your pipes at the front of the engine then connect to that
My bad guess I didn't read properly. Too early in the day
