Pedal Box Ratio's
omega0684 - 21/3/10 at 06:59 PM
i was just having a gander through the Rally Design website and drooling away as usual when i cam across these two pedal boxes.
Pedal Box 1
Pedal Box 2
The first has a ratio of 5:1 & the second has a ratio of 6.25:1, but i don't understand what there ratio's are for?
Can someone please explain what they are for?
r1_pete - 21/3/10 at 07:09 PM
Ratio of the stroke of the foot pedal in relation to piston travel, or cable pull.
omega0684 - 21/3/10 at 07:18 PM
so the piston moves 1 cm when the pedal moves 5 cm?
[Edited on 21/3/10 by omega0684]
britishtrident - 21/3/10 at 07:57 PM
Very difficult to get a decent pedal ratio in any Seven style car even with top hinged pedals.
Even if long pedals are used to get a high pedal leverage ratio the true mechanical advantage depends on where the drivers foot makes contact with the pedal pad.
[Edited on 21/3/10 by britishtrident]
omega0684 - 21/3/10 at 08:17 PM
So what would be best to go for the 5 or the 6.25?
matt_claydon - 21/3/10 at 10:07 PM
Without knowing anything about the rest of the brake system (master cylinder piston sizes, caliper piston sizes and quantity, brake disc diameter) that's rather like asking how long a piece of string is!
However, without a servo most people are looking for the most braking they can get from a given pedal force. You should therefore go for the longer pedal (6.25); the compromise is you will end up with a bit more travel.
britishtrident - 22/3/10 at 01:03 PM
You need to check the dimensions first other wise you could find you are operating the pedals with your heels --- a rather over priced mistake.
Rod Ends - 22/3/10 at 02:03 PM
you can find dimensioned drawings at the wilwood site.
