How Much! O/T
JeffHs - 5/8/10 at 10:40 AM
My wife's Fiesta 1.4 TDCI needs injector seals replacing. Just been quoted £600 +Vat by local garage £400 +Vat by a main Ford dealer (4.5 hours plus parts of around £10).
What do you think?
BenB - 5/8/10 at 10:41 AM
Wow- they really don't want to do that job then!!!
Agriv8 - 5/8/10 at 10:45 AM
Join the club wife 1.4 same problem.
Been quoted a couple of hundred ( providing they all come out ) at my trusted indipendant garage but this could be a 'Mates rate' rather than a going rate.
But this might be sooner rather than later as she called to say it wont start this morning
Regards
tegwin - 5/8/10 at 10:46 AM
How much?!??!??? Christ!
mcerd1 - 5/8/10 at 10:49 AM
that sounds like the problem then
bartonp - 5/8/10 at 10:58 AM
...start soaking in WD40 now then....
Agriv8 - 5/8/10 at 11:13 AM
Good idea but they are not that easy to get to.
the 1.4 is the XUD ( pug ) so not on the dreaded Bosch derv injectors but they can still be troublesome to get out.
Regards
Agriv8
Ninehigh - 5/8/10 at 11:54 AM
If it's what I'm thinking of (the seal around the injector where it screws in) then it shouldn't take 4 hours, unless they're in a right awkward place (engine's upside down?)
jossey - 5/8/10 at 11:57 AM
how muchhhhhh
do they provide the lube or just bum ye up front. lol
Agriv8 - 5/8/10 at 12:15 PM
a good couple of hours to do 'right' and a pain to do re access, washing up liquid on the new seals is known good practice.
replacing injector pipes is also 'Highly recomended'.
some garages quote for replacement injectors rather than just replacing the seals.
regards
Agriv8
rusty nuts - 5/8/10 at 07:10 PM
The injectors on this engine have very fragile nozzles and tips and it can also take a while to clean off the carbon build up around the injectors. Not an over complicated job but to do it right can take a while . Replacement of the injectors isn't a bad idea but not always neccessary
