Hanging an engine hoist..
PSpirine - 27/2/11 at 04:13 PM
All,
I've just bought myself an Aldi electric hoist - nice bit of kit. My dilemma is how to hang it. Hopefully someone here will have a clever solution:
I've got an 8x4" beam spanning across the garage, so I'd like to hang it off that, directly or indirectly.
The hoist mounts are two U clamps, the opening of which is 2" (accepts both round and square profile), and the bolt hole centres are 9cm apart.
Any ideas must involve only bits purchasable from B&Q/Jewsons/ebay (i.e. I can't cut/make anything out of steel), and must be *proper* locost!
Thanks,
Pavs
PSpirine - 27/2/11 at 04:20 PM
Incidentally, I've got a lot of 6x2" wood that is waiting to be used if there's any way of adapting that!
Ta
zilspeed - 27/2/11 at 04:20 PM
Here's how mine is mounted.
Those are skateboard wheelbearings off ebay.
Hoist in position LHS
froggy - 27/2/11 at 04:25 PM
cant help with your problem but i bought one a while back and with the cable doubled it lifted my saab engine/box no problem around 250kg. i use a scaffold tube running opposite to my roof joists 6x3 and move the car out of the way once lifted.
PSpirine - 27/2/11 at 04:25 PM
Cheers for that, but that won't work in mine unfortunately.
My beam runs across the garage, not lengthwise, and it's by itself (i.e. I can't span anything between it and another beam)
Thanks,
Pavs
JoelP - 27/2/11 at 04:30 PM
can you drill steel tube? If so, attach the hoist to about 2 foot of 2" square tube, drill a few holes, and simply use massive wood screws to hold it up to the beam. I mean about 6" 12g screws.
PSpirine - 27/2/11 at 04:42 PM
I can drill steel indeed, and that was my first idea, but I have to say I'm not 100% confident in hanging the whole thing off screws going Up into the beam without any sort of positive support!
Cheers, keep em coming!
Chippy - 27/2/11 at 04:59 PM
I don't have a posh electric hoist, just a Terfor winch, but the way I have mine fitted would be just as good for a leccy one. I fitted a piece of 50mm x 50mm x 6mm angle to the bottom of a joist, (100 x 50), which crosses the garage side to side and screwed it up every 8" with 3" No 12 screws, then fitted a hoop to the middle to attach the hoist. This has been used several times to lift the Cosworth V6 fitted in my car, ( bloody heavy lump). Will get a picture and attach it so you can see what I mean. HTH Ray
Hoist
Hoist
[Edited on 27-2-11 by Chippy]
coozer - 27/2/11 at 05:23 PM
Mine runs on 2 2" angles welded together, bit of steel channel and 8 50kg castors from ToolStation
[Edited on 27/2/11 by coozer]
