Having read various guides..... The aim is a rectangle aligned to the rear wheels.
Question is, how do you achieve this without measuring the diagonals? You can ensure the sides are parallel but if your front and rear axle were
slightly offset how would you pick it up?
You need a datum point, normally, the centre of the car - measured from the centre of the rear axle (if symmetrical) or a known centre. From this you
should be able to measure the wheel track and make markings until its square and symmetrical.
After youve done this, it gives you more datum points to measure the fronts.
Question is, how do you achieve this without measuring the diagonals? You can ensure the sides are parallel but if your front and rear axle were slightly offset how would you pick it up?
I'm considering doing it on my daily cos it will need done about 3 times in the next few weeks and while I cant warrant the tyre wear, I
don't mind if the wheels in the piss. I was just curious about the thrust angle thing, I can see how its done on a spaceframe fairly easily, just
not on a curvy monocoque!
If there was something simple I was missing it would have satisfied my curiosity as to just how bad the rear axle alignment tolerance is from the
factory!
It is quite handy to provide front and centre line datums on the chassis at the building stage,
It really is quite tricky to get everything pointed on the right direction but thankfully very smal errors are critical. My personal (lazy) method
was to get one rear wheel pointing as close as possible to the correct direction then set the the toe-in accross the axle. A rear wheel should
never toe-out, always err on the side of toe-in.
On the front just equalise the track rod length and adjust the toe-in accross the axle equally on both tracknrods, if the steering wheel is off
centre you can turn it on its splines. Again it pays to err on the side of toe-in but nothing like as critical as it is on the rear.
Measuring the diagonals between tyre contact patches will tell you if it is square or not. To get a consistent point to measure from use two try
squares cut out of mdf with a small screw in the corner. A bit like a solid capital L shape with a screw at the elbow.
Fit the squares flat on the ground snug to the inside of the wheel between a diagonal pair and measure length. Do it a few times until measurements
become consistent. Compare diagonals.
If the rear axle is 1 deg off square the diagonals will vary by 22mm so you can see this is surprisingly accurate. Usual caveats of blowing up tyres
adjusting other stuff bla bla bla.
Cheers!
