Hi all I am looking to get a bit of ally or steel turned to make a mount for my paddle shift. Nothing too complex 45mm stock turned to 40mm one end
and 42mm the other with a 30mm ish hole thru the middle.
Does anyone on here do such things on here? or can anyone reccomend a machine shop in the west of scotland that doesnt charge the world and his
wife??
Also can anyone suggest a stockist of 45mm steel bar? plenty of ally on the bay but no steel.
Hi we can do that willsend you a u2u if you can't get it done locally
atb
Mike
For small quantities of steel, I use Metal Supermarkets, down by Ibrox. Might be worth giving them a ring.
Jek
Metal Supermarkets
0141 440 1300
Units 2 Moorpark Ind
Moorpark Industrial Estate, Glasgow City G51 2HF
I know someone over here that can machine that for you if you can't find anyone closer
Mike (trextr7monkey) sorted it for me. Did a cracking job and in super quick time too!!! Many thanks
Thanks to all who offered aswell
