any skoda tec's help
JAMSTER - 20/7/11 at 06:39 PM
i have a 04 skoda superb 2.5tdi v6 with no power/pull i seem's very flat i have so far replaced air mass sensor,changeover flap,boost pressure sensor ,can't see/hear any air leak's and the turbo has been sent to a turbo centre and all is good and to top it off no fault code's
hellllllllllp
Mark Allanson - 20/7/11 at 06:46 PM
These symptoms are normally associated with intercooler pipes coming adrift or a punctured intercooler. The pipes have special clips which can let go, renewing them is the only remedy.
T66 - 20/7/11 at 08:09 PM
My Saab turbo has had similar issues twice over the years, and both were intercooler pipes.
The bottom one was loose, hidden under the mass of pipes & stuff, and wasnt too obvious till I realised the clip was loose.
The second time was the easier one, when the plastic hardpipe into the throttle body popped off.
ko_racer - 21/7/11 at 08:53 AM
Sounds like a leak in the intercooler pipework or a blocked exhaust.
Best bet would be to make a simple boost hose tester. Block each end of the intercooler pipework and pressure test it with compressor.
JAMSTER - 22/7/11 at 05:19 PM
thanks for the info blocked exhaust was the problem
