I've taken on the task of helping out a mate who is building a landy in the style of a Bowler Tomcat. He has based it on a 300tdi donor vehicle (
discovery 1994 300tdi 5 door non aircon and non abs).
My job is to strip the loom of all non required wires so that all that is left is basic lighting, wipers, etc. No fancy extras. After that is done we
will add in the spot light and winch wiring to suit along with any other ancillaries he wants.
I'm looking for a wiring diagram that is as in depth as possible. The haynes one I've been given does not give the same colour codes as the
loom that is in. I think its the wrong age of diagram. i also assume that the base loom will have all the take off points for the abs and aircon etc
etc etc terminated in plugs for easy connection at the options stage of the factory.
So can anyone help with a link to a detailed diagram or a file they could send me or scan in. Or fax if its in paper form.
Thanks in advance folks
You need the "Landrover Rave" CD google for it or just do an ebay search ---
Ralph Hosier will have an answer, twitter him. Quality bloke with a deep knowledge
http://www.rhel.co.uk/
[Edited on 29/3/13 by T66]
Defender2.net will also have your answer .
