I bought some new alloys for my daily driver and I am needing to bond the supplied plastic spigot ring into the bore of my alloy wheels to prevent them moving and becoming misaligned when fitting the wheels to the hub (as is what is currently happening). Any suggestions on what would be best to bond the two together?
Are you putting the rings in the wheels then fitting the wheels? If so try putting the rings on the hub then sliding the wheels over the top. I always find it easier that way and once you've got a few miles under your belt the road dirt will help hold them in place a bit better.
Couple of spots or a smear of silicon should do it, and not too permanent if you want to remove them in future.
....to prevent them moving and becoming misaligned when fitting the wheels to the hub (as is what is currently happening).
If you pop the spigot into the wheel bore it is as you say a circle in a circular hole, however when lifting the wheel onto the hub the spigot is moving forward unevenly as it is not secured in the bore of the wheel so it is actually at a slight angle as the wheel mounts the hub. The car has tapered hubs (which I think is not helping) so rather than the spigot centring itself onto the hub as the wheel is pushed further on the spigot is just being pushed back still at an angle so half the spigot has moved down the hub onto the tapered section while the other half is more or less where it should be on the hub.
Picture of hub (not mine) pinched off another forum for reference. The spigot should be sitting on the outermost part of the hub.
Can you get a pic of the wheel with the spigot in place?
Fit the ring onto the hub (secure with a bit of silicone sealant if you want it more secure) then put wheel on after.
I guess the taper on the hub spigot is the issue
Maybe some longer spigot rings would sort that
What does the centre of the OE wheel look like ?
[Edited on 2/3/2017 by mcerd1]
Here is the OEM wheel, I have measured everything and if I can get the spigot to stay in the bore of the aftermarket wheel then it will locate on the
hub in the correct position and match the OEM wheel.
Such a massive chamfer! That are they from? Whats the oe hub look like.9
Mk7 golf gti, that is the back of the oem alloys. The hub is as the first pic
This might be a silly question, but can you use the wheels without the spigot rings? Once the bolts are torqued up there won't be any forces exerted through the ring. If the bolts are tapered they should align the wheel themselves.
Did the spigot rings you've got come with the wheels?
Have you got a set of digital calipers ?
If you can take a few measurements we could work out the dimensions for a spigot ring that works better
Interesting hub flange, I'm seeing(?) the OE wheels for that setup sit on the external flange diameter. You're attempting to centre the
wheel on the diameter at the hub face, which is less. You need a different shape of spigot.
What would I do, I'd machine the taper OD off the hub if possible (I can't see if there's enough internal material from the pictures to
take that approach).
Yes Spigots came with the wheels (Wolfrace) and are the correct size, they fit in the bore well enough but just not tight enough that they have to be
tapped in and stay in of there on accord.
When I fitted the wheels oringially I was getting a vibration hence removing them and investigating to discover the the spigots were not staying in
the correct location when the wheel was offered to the hub.
I have ordered another set of spigots off fleabay just for comparison and I am planning to put some thin tape around the spigot to see if that is
enough to make it a tight fit into the wheel bore so it stays in position.
Originally posted by motorcycle_mayhem
Interesting hub flange, I'm seeing(?) the OE wheels for that setup sit on the external flange diameter. You're attempting to centre the wheel on the diameter at the hub face, which is less. You need a different shape of spigot.
What would I do, I'd machine the taper OD off the hub if possible (I can't see if there's enough internal material from the pictures to take that approach).
here's how I see the problem
If dimension A on the hub is greater than dimension C of the spigot ring then it will easily fall out of place (assuming its ever long enough to reach
in the first place)
on my borbet wheels the plastic spigot rings that came with the wheels actually clip solidly into place - once they are in they are very difficult to
remove again - but if your ones just push in then that could be the problem, but I don't think glue would be the best answer...
if its just that they aren't long enough at all then 'longer' spigot rings would be the only real answer
I've sketched up a couple of ideas:
Agree that is a spot on analysis and is the same conculsion that I came too aswell. I obvioulsy don't want to go down the custom spigot route if
possible but if I was I would ensure the spigot would be flush with the edge of the wheel so it sits directly against the face of the hub so movement
is not possible.
As annotated in your sketches the problem is the current plastic spigot is not a tight fit into the wheel bore. It is snug (very minimal movement)
but not tight and does fall out if you tip the wheel. I reckon if it had an extra 0.5mm-1mm onto it's diameter then it would be a tight fit.
This is why I think some form of glue to bond it would resolve the issue. As mentioned previoulsy I have ordered a another set of spigots from a
different source so it will be intersting to see if the tolerances are the same or not.
I obvioulsy don't want to go down the custom spigot route if possible but if I was I would ensure the spigot would be flush with the edge of the wheel so it sits directly against the face of the hub so movement is not possible
