I am looking to be a bit creative and perhaps assemble a JBA Falcon type of car using an MX5 donor.
Now the JBA Falcon has its own chassis and the challenge is to integrate that with the MX5 parts.
If I understand it correctly the MX5 has a front and rear chassis joined by a central 'rail' that offers little or no integral strength to
what would be a complete rolling chassis.
My first thought would be to isolate the front and rear chassis assemblies and then integrate them into the JBA chassis to make a single structure.
This would solve most problems of mounting the various major components of engine, gearbox, diff and lower suspension brackets.
My first question is "do the MX5 front and rear chassis have enough inherent strength to make this a possibility"
Notquite right.The MX5 has front and rear sub-frames mounted to the body shell but also joined to each other with a beam between them. The sub-frames are substantial enough and the beam is there to add ridgidity, as the shell (being a soft-top) alone would have too much flex.
Excellent news guys so far.
Next question
The donor car will almost certainly be an MOT failure due probably to rust problems.
I know rust affects wings, cills etc, but do the subframes escape the ravages. If not where to look for damage for problems.
Just to add, the beam connecting the subframes also acts as gearbox support/mount.
Sub-frames do succumb to metal rot. I've just stripped an MX-5 with not a lot of meat left on the rear sub-frame. Front sub-frame was fine and of course, the aluminium PPF linking the two was untarnished. What you might want to consider is retaining part of the PPF to act as gearbox support.
Good suggestion about the PPF (whatever that stands for
If the rear subframe is shot can (new) replacements be bought, and if so where?
Power Plant Frame, the bit that links the two subframes together. However, if you do this, you'll have to ensure that the chassis gives good
alignment between the gearbox and diff. The PPF guarantees this. Many kit cars do not use the PPF, my future Vortx included so just follow whatever
practice they use.
[Edited on 5/8/2015 by micksalt]
The ppf doesn't link the subframes together with any strength, it links the gearbox casing to the diff casing, both of these are rubber monted to
the subframes (well the engine is, not the gearbox)
[Edited on 5/8/15 by prawnabie]
Not that I know of, but there are literally hundreds of MX5's being binned that have perfectly good rear subframes. Take your pick.
One thing to be aware of (if you don't know already), the subframes don't hold the upper suspension mounts. The car itself has to bridge the gap between subframe and top mount.
MX5 already uses coilovers, they're just a bit big and not adjustable. Reusing the same design upper mounts should give you plenty of options, although depending on the weight of the car you might need to reduce the spring rates?
Chassis rails rust
Originally posted by maccmike
Chassis rails rust
Surely that works in your favour though? It just means that Mark 2's end up as MOT failures in bits of the car that you're not planning to reuse?
My mk2 was terrible with rust, including the chassis rails. The rails crumpled during jack up, as for the floor pans, literally crumbled to touch.
Typical Jap cars, good running gear but poor corrosion protection on bodies.
Stu
Totally agree, I was all up for buying an mk3 mx5 until I just gave up finding a rust free example, some of the undersides were horrific and looked
like the whole car had been parked in the sea even though the upper bodywork looked immaculate. Even suspension and subframes looked in dangerous
condition.
Tbh I’m seeing this with quite a few jap cars and my Almeria, Corolla and Avensis where all basically written off due to terminal underside rust that
was just not worth fixing yet they all looked great from above. Hence I’m back to the Volvo’s which are really well protected underneath.
