Thought ii had some play in my rack but its the triangle shaped slipper part of the steering column, can this be fixed or is it normal for a tiny bit of play?
Not sure if this helps but the triangle shaped bit on mine is pushed in tight to a pillow bearing and I have no play in it that I can see....not the
best picture but hopefully this helps
engine in2
The bearings come from simplybearings.co.uk
I have the same fix as Peter.
There was a load of wobble due to no support on the column, probably from end to end.
It works a treat and I have no noticeable play now.
Or are you referring the telescopic collapsible part? In which case there is a little plastic shim that should be in there to remove that movement.
Is it a Sierra column?
mine looks something like this from memory
https://www.ebay.co.uk/itm/Ford-Sierra-Steering-column-Bush-Kit-Kit-Cars-Steering-STE0008/253203065949?hash=item3af4142c5d:g:6ZEAAOSwTuJYpt5n
I just have the triangular plastic bit and I think that is held on with a jubalee clip to stop it sliding back out. Also means if I need it to
collapse, the jubalee will just slide up the shaft.
[Edited on 30/10/17 by bi22le]
Just ordered a sierra steering column bush kit which should have the bits to fix the niggle, cheers all
