SSS stylus track set up?
number-1 - 17/6/19 at 05:33 PM
Can anyone offer some advice on suspensions setups for track days on the SSC Stylus? Its got Pro Tech shocks front and rear. I just need a rough idea on a good base setting for the car and a 16 stone driver.
If not, can anyone suggest a firm that can set the car up.....ideally close to Aylesbury?
se7ensport - 17/6/19 at 07:14 PM
It really depends how they have been valved and the spring weights.
Matt at Procomp is the expert on valving and setting them up.
If they aren’t in need of a service take it out and have a play with the settings. Add a couple of clicks and see how it feels to you.
number-1 - 17/6/19 at 07:48 PM
They are new! The previous owner fitted them less than 100 miles ago. Spring weight....no idea
Ive got a track day evening at Bedford next week so will have a play. 243 bhp on a supercharged engine should be easy to handle.....
Dopdog - 17/6/19 at 10:57 PM
Yeah that will be OK, once you have tuned it up a bit for some more power you will need to really look at the geo but what you have will be great for popping down the shops and an evening track stint. 🙄
