I have to rebuild my diff. Any change to get it out without removing the fuel tank? Is it worth giving it a try?
I released the two lower trailing arm bolts on the axle and tilted the axle casing back so the diff nose was facing down at an angle, this gave enough
room to drop the diff out.
The fuel tank shouldn't be an issue unless you have a larger custom tank in there, the original mini van tank leaves plenty of room to work.
Dave
This question will be answered TOMORROW. . . . Kind of!
A new episode is out tomorrow on https://www.youtube.com/@TeaNBizz-Kits where I race against the clock to remove my diff from my IRS striker.
Please take a look. Its an extended episode which covers some custom 3D printed parts, compression testing my engine and POR15.
Also subscribe and check out the other episodes. THANK YOU!!!
[Edited on 13/3/25 by bi22le]
Perfect, thanks guys! I will find out Saturday ;-)
Well it’s Sunday is the diff out
G
Yes, diff is out. What I learned:
- You need a slide hammer to pull the half shafts
- Fuel tank can stay
