Alright?
I need a handbrake cable to link a mini handbrake to a Sierra handbrake yoke, about two feet long, any ideas?
Chris
How about a drawing Chris? Do you mean a Mini handbrake lever or the linkage in the drum? What do you mean by Sierra handbrake yoke ?
Rover 200 handle with Freelander cables. Works on mine better than the Ford rubbish.
Seeing as it's you Rusty!
Chris
Does the cable have a straight run ? if so how about a rod? How friendly are you with your local motor factors, ? Will they let you look at thier stock? Failing that, Speedy Cables can make you one from a drawing . Can't think of anything else at the moment
Have a look at the Rover 214 front cable & handbrake lever
I use the cable B&Q sell off the roll! They also sell the proper connectors. It's held for a year!
Thanks Chaps!!
Gives me something to think about.
Chris
