Hi guys,
as above, i need to find an inline fuel filter to go between the pump and injectors. Anyone know where i can get one?
Dave
Your local motor factors.
Bike filters are small. But otherwise anything designed for injection...
Try for cheap and simple....
Ebay linky
[Edited on 30/1/09 by BenB]
Cheers guys! That is cheap!
Plastic and paper filter, local motor factors, 99p.
I don't think ours was made in Israel
Are you using the R1 fuel pump?
If so, it has a built in filter mesh.
I've looked in the R1 manual and there are no others in the fuel system.
yeah i'm using the R1 pump but just thought i should put another filter in to make sure no crud gets through to the injectors
I'm not bothering as the bike doesn't have one.........
And I'll be using a tank mounted pump and filter with nothing else. It was good enough for Yamaha.........
