Cars been on a trailer for the 3rd time since being built.
Now safely in its new home waiting for the duratec to be test fitted
New home
Got a little more space to get around it now as well.
looking good. every time i see your car i always think it looks so pretty and that its such a shame that gts cant get their act together and get more
of them on the road.
do i spy the duratec in the background hope it will be in and running for stoneleigh you cant be far off fitting it now? unless its just the
camera angle it looks like you could do with a few more lights in there?
also did you buy or make the workbench? im after a new one as the one i have is too big.
[Edited on 17/1/10 by ashg]
Envious about the space youve got!!
Looking good.
power and a work bench you lucky git
very interested in seeing the end results of the duratec conversion, i think its gonna be a cracker
Excellent, Looking very good!!!
Thats nearly 3 times bigger than mine!!!
Built the bench a couple of months ago. About £70 worth of wood and a day to make. Nice and sturdy (legs are 4" posts).
Could do with a few more lights, but its not too bad as I have some portable halogen floods.
Yep thats the duratec hiding at the back
so finished for stoneleigh? or are we not divulging
Originally posted by ashg
so finished for stoneleigh? or are we not divulging![]()
We will see![]()
are you renting the space dave or have you moved to a new place?
In the process of moving
Jealous of that garage Dave.
Light would be better if it's given a coat of white paint, but it's a good size.
In the process of moving![]()
Not bought a house sadly. I am moving in with Sarah. There is a flat attached to their house, which they own, and her parents have said we an stay
there as long as we pay half the bills.
So really its a cheap, but great, stop gap while we are still saving for a place of our own
We are in the process of renovating the flat itself, but I got the garage finished first so moved everything in there
Happy Days!
Thats far too clean garage!! You are getting as bad as me with cleaning of the garage.
Perfect size garage david,very workable.
As said earlier white walls would help.
White walls would be good, but as the building is very old, and the walls are a bit damp I dont think it would be a good idea.
Its not as dark as it looks in the pics. There is a window which is currently boarded, which I intend to open up which will let a lot more light in.
You might be able to cure the damp a little by checking the drainage/guttering,and if you do paint the walls one trick i have used is mixing in PVA to bond.
v.nice. I wish i could find somewhere the same size to rent, i'm sure they must be out there but the local papers are no use, gumtree the
same, arrrgh!
Sounds like an ideal arrangement, and you have your priorities in order. Nice to see in young people these days. Having a refuge will allow much $$ savings, as you won`t be in the pub as often. Do mention this often.
