Hello Lads
a mate at work has just contacted me with a problem he has with his desktop computer
He turns it on at the mains and it powers straight up but nothing is showing on the screen
It doesn't seem to turn on or off using the on/off button on the tower
i thought it might be just the on/off switch but why is there no display to the screen ?
is this 2 seperate problems ?
he's not getting any mad sucession of bleeps from the motherboard
cheers for any help
perksy
i'd start with PSU
Sounds like the screen is either unplugged or gone up the swanny to me, have you another screen that can be used to test.
Rich
could be the graphics card? if he has fitted an 'after market' card worth trying to connect to the original vga output....had that with my daughters pc recently - spent ages despertaley backing up the info as was sure that the thing was on the way out - only to find that the super dooper graphics card was broken.....
Hello Lads
Originally posted by Airhead
That is almost definately a fritzed PSU.
The machine shouldn't be turning on without the intervention of the power switch - if it is and isn't throwing out beep codes and if the
monitor is blank it is fair to assume that the PSU is faulty and whilst able to power up the fan it isn't supplying the graphics card with
sufficient juice.
I might be wrong, I accept that, but what on earth does a faulty graphics card, sVGA lead or whatever have to do with the fact that it doesn't
switch on using the power switch?
15 years in the trade, I'd be trying the PSU...
Apologies - I just re-read the original post and saw the reference to the mains switch not making any difference.
Yep, I agree it has to be the PSU - I've also been in the trade for a few decades and simply missed the detail
is its a E-machine with a p4 478 by any chance ?
