Does any kit manufacturer use a modified front upright from a mass-produced FWD car on the front of their RWD kit car?
I only ask as I have a FWD reverse-trike itch that I think may need scratched (*) and it would make things a lot easier to use the front-corners of an
established kit.
* until I get bored with it, break-it, and sell the bits to you lot!
Quantum did as did Midas, but they took the whole suspension from the donor.
Which is something youcould do as well
[Edited on 27/8/14 by ettore bugatti]
I had thought about using the entire front-end components from the donor (Ford Puma).
I'm not sure how easy it would be to get the existing Macpherson strut arrangement to work well on a 350kg vehicle though.
The Quantum Xtreme front uprights look like they may have been used for a FWD vehicle, but I can't work out which one.
More a case of packaging the strut so it doesn't look like dogs diner.
Sylva mojo
And the onyx firecat springs to mind.
Classic mini with stripped out CV joints has been used many times, no modification required, fairly light and double wishbone from the factory.
Best image I could find.
[Edited on 27/8/14 by iank]
Quantum Extreme has a custom upright with Sierra hubs IIRC.
350kg is light, an option could be to use ATV suspension.
If you dont want to alter the track width of the Puma donor. I would use the whole package, but replace the springs and shocks for some coilovers with
springs matched to the new weight and the ride height fine adjusted on the shocks.
As said you need to pay a little more attention to hide it visually, but that shouldn't to much of an issue after a little practice.
Give Martin Keenan MKengineering a call he designed some for the Midi he built so should be able to let you know all geometry settings etc
Originally posted by ettore bugatti
If you dont want to alter the track width of the Puma donor. I would use the whole package, but replace the springs and shocks for some coilovers with springs matched to the new weight and the ride height fine adjusted on the shocks.
PS - just in case it's not clear... I'd make an arse of the geo if I'm left to my own devices!
PPS - I have the Puma and the Smart bodywork (leftovers from previously abandoned projects).
Originally posted by scootz PPS - I have the Puma and the Smart bodywork (leftovers from previously abandoned projects).
I'm sure that didn't come as a surprise Wasa!
Metro/MGF?
so you do keep some things then Scootz
Originally posted by adithorp
Metro/MGF?
Same front upright though.
Another vote for classic Mini/Metro from me.
As iank says, it's relatively light, compact, cheap, easily sourced and it's double wishbone, whereas most of the competition is on
struts.
Another one that's been used successfully is early Renault 5.
Long in the tooth and rare, now, but it has the advantage of not only being double wishbone, but offering a complete longitudinal engine and
gearbox package that doesn't result in the tall, bluff front end that you automatically get with a transverse front engine:
http://www.flickr.com/photos/91461951@N08/9646655057/in/photostream/
Personally, though, I'd go for Mini uprights, with a 2CV engine/gearbox (for the air cooling, low CoG and inboard front brakes), or failing that
a Guzzi engine coupled to a VW box:
[Edited on 27/8/14 by Sam_68]
As iank says, it's relatively light, compact, cheap, easily sourced and it's double wishbone, whereas most of the competition is on struts.
Long in the tooth and rare, now, but it has the advantage of not only being double wishbone, but offering a complete longitudinal engine and gearbox package that doesn't result in the tall, bluff front end that you automatically get with a transverse front engine:
Personally, though, I'd go for Mini uprights, with a 2CV engine/gearbox (for the air cooling and inboard front brakes), or failing that a Guzzi engine coupled to a VW box:
I'm not fussed about the front looking a bit 'industrial' as it will be covered. The rear chassis will be a simple single-seater exo type.
MGF front upright is a metro item - it even has a stub driveshaft in it I'm told!
I know what you're saying Sam - I don't think that I've seen one that looks right either.
I have a picture in my head... Smart Roadster front tapering towards the single seater frame immediately after the wheel arch... door panels and wing
cut along the crease line and only the top portion used... and meeting the frame at the very end below the roll-hoop (or possibly meeting just behind
it to form the rear mudguard?).
Kind of like a 340R, but with the front wheels enclosed and a tapered chassis / bodywork. Oh, and a batmobile-esque wide rear tyre.
Not looking for precision handling (clearly!). Just something that's reasonable fun to drive and the right side of 'safe' (whatever
that may be), And to actually FINISH a project!
Coilover on McPherson
http://img215.imageshack.us/img215/4397/img106s.jpg
Isn't s Smart Roadster/Coupe not a bit narrower than a Fiesta/Puma?
You could try the race kits Falcon - it's a 750 formula car and uses the uprights from the Seicento. The rear end is converted to de-dion though
so might not be suitable.
As everyone else is suggesting, I would also go down the mini/metro/mgf route. Here is an interesting link - showing the different lower ball joints
for changing the castor angle. http://www.obsessiveperformancedisorder.com/forum/viewtopic.php?f=19&t=16864&start=60 (about 3/4 down the
page).
The only issue with MGF is the odd PCD of the wheels but I don't think it would be a problem getting them re-drilled.
[Edited on 27/8/14 by bozla]
The MGF basically uses two metro front subframes. The front still has an outer CV joint in but not fitted with the ball bearings cage and drive shaft.
I've often looked at them as crying out for a twin engine conversion.
You could use the puma uprights with a mushroom in the top like when Sierra uprights are used on 7s
Originally posted by DW100
The MGF basically uses two metro front subframes. The front still has an outer CV joint in but not fitted with the ball bearings cage and drive shaft. I've often looked at them as crying out for a twin engine conversion.
Ginetta G32 - Mid engine RWD uses the Ford Fiesta MK2 hub and upright at the front. They replaced the drive shaft with a couple of machined spacers
and a 1/2" bolt. Upper fitting is an adaptor to fit a ball joint.
Early Tiger Super sixes used the Golf upright and lower wishbone.
Andrew
Metro/MGF?
Hadn't thought of the Metro. Cheers.
MGF? Is that not mid-engined RWD (fixed position uprights)?
Scootz Did you get any where with the red RX8 you purchased for a project?
[Edited on 28/8/14 by ceebmoj]
Gutted it and scrapped the shell.
Mulled over the engine and gearbox for a while, but decided it was going to cost too much to do it right.
Chopped it in recently and got my money back (for a change!).
