Alright fellas,
Just wondering...If i followed 'the book' (second edition) to the letter,will i come up against any problems, flaws, misprints etc or
anything like that i could do without?
Thanks in advance....Russ
Probably!
LOL Cheers for that mate
oh yes there are a number of problems(allegedly)
start by using the mcsorley plans
they are meant to be better
and i think the front suspension pickups give an incorrect castor angle with cortina uprights
Get a copy of McSorleys? plans and use them with the book.
That's what I did and there have still been a few things I "could have done without".
mcsorley
hope this helps
Hi Russ,
We built 2 chassis as close as you can get to the book, all I can say is ignore those that say the book is full of errors, build to the book
dimensions. I'm not saying there aren't any errors, but they are so obvious when you get there. Ok you may cut 2 pieces of steel wrongly,
but don't worry about it, it's all part of the learning process. I found the book to be an excellent guide and have 2 cars on the road to
prove it!!
Marcus
Also have a look at http://www.locostcarclub.co.uk
there are a few tips on there
Cheers guys.
