Emissions...
AntonUK - 12/1/16 at 08:29 PM
Im trying to work out what emissions test my car will be subject to come MOT time. Its never been tested in my ownership.
Its a a factory built (was a Kit) Ginetta G27, registered in 1996. As far as I know i still have the original exhaust and manifold and it does not contain a CAT.
in the MOT manual is see the following text
“For emissions purposes only. Kit cars and amateur built vehicles first used before 1 August 1998, are to be considered first used before 1 August 1975”
Which only carried the visual only inspection.
Thoughts anyone?
rusty nuts - 12/1/16 at 08:43 PM
If it has a Q regs then it's visible smoke ,if it has an age related plate then it will be tested to the emission requirements at the time of the registration . Might be worth checking your V5 registration document?
mackei23b - 12/1/16 at 10:16 PM
Have a look at mot testers online manual, some test centres will do a Q on a visual test, but the manual flowchart will refer to the age of the engine and registration date that determines emissions not a registration plate....
All the info here http://www.motuk.co.uk/images/730_newnoncat.pdf Looks like you are ok for visual....as far as I can see....
Cheers Ian
[Edited on 12/1/16 by mackei23b]
AntonUK - 12/1/16 at 10:16 PM
I cant get access to my v5 atm unfortunately.
The car is on a 96 N plate. Which would mean a CAT test with 0.5% CO. Which cannot be correct due to the lack of CAT and it originally came on Weber DCOE's which I very much doubt would have passed that level of testing.
It sure is a minefield...
prawnabie - 13/1/16 at 10:26 AM
What is the age of the engine?
AntonUK - 13/1/16 at 06:10 PM
Engine age is unknown current engine (which was a direct replacement) was an eBay special.
gremlin1234 - 13/1/16 at 07:13 PM
does this page (the standard tax check page)
https://www.vehicleenquiry.service.gov.uk/
have any info on co2 emissions for it?
needs no. plate and make
AntonUK - 13/1/16 at 10:39 PM
Unfortunately not
CO₂Emissions : Not available
alfas - 20/1/16 at 07:20 PM
i thought the emission class in UK is determined by the engine age, not the reg.-date?
rusty nuts - 20/1/16 at 07:45 PM
If the presenter can't prove the age of the engine the tester will test using the vehicle registration date.
AntonUK - 23/3/16 at 01:34 PM
As closure to this.
I presented the car for MOT and took both my V5 and a printed copy of MOT emissions handbook pdf. Showed the MOT man and he accepted that its was visual only and passed me.
40inches - 23/3/16 at 02:42 PM
For future reference, for anyone who hasn't got one you can download the official manual here
Go to section 7.3 page 1 and the bottom left corner:
"Q plated vehicles
are to be treated as being first
used before 1 August 1975 for emissions purposes."
Which is good for me, as the V5 for the MK states that the emissions are tested as post 2002
