Hi Guys,
I think i've created a palindrome of words there!!
I'm having some trouble with my fuel pump.
Its a bosch inline type style, but just can't get it pumping and i think it's supply to the pump rather than anything else.
With the pump connnected, i just can't get it pumping fuel down the fuel line, or even with the end pipe off doesn't want to know.
I can siphon fuel from the tank with the pump disconnected, so would appear to be running free enough, but the pump won't pull the fuel
through.
So just after some advice here, i've heard that you have "push" or "pull" type pumps, so not sure if mine's just not up
to it?
Some photos to give an idea of the setup:
Oh and ignore the stain that looks like the tank is leaking - it isn't....
[Edited on 22/3/17 by pekwah1]
Change the wires over would be my first thing to try
by wires, do you mean pos + and neg - ?
I haven't done this, but did switch the hoses round in case i was being a moron, didn't make any difference.
I had an M5 and M4 connection on the pump, i've put neg to M4 and pos to M5
Yes i had this setup originally, but not at the moment, maybe i will change it again....
that style of pump doesn't suck, it requires flood fill
often the easiest way to do this is with a LP pump, unless putting the HP pump inside the tank is possible.
Thanks guys,
so a LP pump would generally suck (i.e. the facet type?)
That's actually the setup i had on my previous car with a swirl pot, just haven't got round to buying the LP and swirl yet...
Your wires are reversed.
Should be M5 to ground, M4 to 12V (Well, hopefully a bit more than 12V, but you know...)
The "+" and "-" are actually labelled on that brown plastic/resin output end. They're just REALLY hard to see.
Hopefully the pump hasn't been damaged by running dry.
Good luck!
Steve, in the NLs
Or gravity feed it from a new tail fitted to the bottom of the tank. That worked on my last car: pump mounted 1cm lower than the tank, and I also fitted in in-line swirl pot horizontally to take the return from the engine bay so that the fact that tank didn't have baffles didn't matter.
I have a facet pump and was told it needs to be mounted near the tank outlet and low. It doesn't like to suck uphill much but will push the fuel to the front end ok. That's what I did and it works a treat, keeps the twin 40's fed and without a pressure regulator. I intended to fit a reg, but found it didn't need it.
You'll all be glad to hear that since this post I have now bought a facet pump and swirl pot, so will get it hooked up once it's arrived and all should be good in the world!
Have you switched the wires around, yet?
Do that first or you'll continue to toast your pump.
Again, M5 for GROUND/EARTH, M4 for power feed.
Prime the pump somehow, then turn it on and see if you still need a feed/lift pump.
Steve, in the NLs
No haven't swapped the wires yet, decided to just get a facet and swirl pot anyway so will get them installed first and see how I go!
Well, I double-checked my own pump, yesterday (exactly like yours) and confirmed that the larger terminal is for negative/earth/ground.
The + and - signs are there, but very difficult to see.
Funny, a Google search showed the symbols like I just described, but the text description wrongly said to connect them like you originally did.
Indeed, it's a bit counterintuitive, but it reiterates that the ground side of the circuit is AT LEAST as important as the power feed side...
Thanks, i took mine off and there are NO symbols at all.... just made the assumption a bigger terminal must be live, but you know what they say about
assumptions! Anyway, Low pressure and swirl on their way so i guess i'll stop cutting corners and just do it properly now!
