I'm after some metal (assuming aluminium) u-channel with a 2mm groove in it - and in true locost style - and trying to do this as cheaply as
possible. Not least because it might not work for what i'm intending...
I can see something like what I have in mind exists - e.g.
https://www.clickmetal.co.uk/click-by-category/metal-mouldings/aluminium-miscellaneous-mouldings/aluminium-misc-moulding-no-10/?gclid=CjwKCAjw7oeqBhBw
EiwALyHLM726FV7mbOkmumF56MSj08pQfCsxUyNO7-WdvG6xA_sCY-CgSUzPTxoCnAwQAvD_BwE
and
https://www.ebay.co.uk/itm/265749500156?var=565534255106&hash=item3ddfe790fc:g:-hQAAOSwHhBitDoh&amdata=enc%3AAQAIAAAA8E1UD58CqP6Xd%2B4o9gelAwp
gWrW1Jf%2Bdu8dEgl5BnC0vggXtK2U6xBGyzknFPLPN4Q0zmdKtg%2FyOy%2FUXREfisAVzVIcvSGtnJA5uPQuoPJodxxMbl6NS9Nbr0TRzbV29K2QemjYbmM50PCaWhyzp9xxqtJ5cAY2aLV%2FxE
wA5G0yVhSMAuivFINLpz2cGY9khBBTrCZ%2Br7ssPI%2FA0vX%2F7ryyG9D1c4I4NsJsKW6ELOMqxSre7SqDnyWUFRHyCDdl9OKMFVlQLPs5BoqVjFDxMMjGDI0Mpu%2BuP5F1kL12xXDw4cqhSRp1
fukfWwztlji2WLQ%3D%3D%7Ctkp%3ABk9SR96Zy6jxYg
But where could I scavenge some for free... I only need about 300mm of it...
I'm not above digging in skips to pull it off fridges/etc if i'll find something appropriate somewhere like that...
[Edited on 1/11/2023 by jps]
How about shower glass edge trim? Although I'm not sure about 2mm, toughened glass may be thicker than 2mm.
Can't think of a logical source right now, but for the sake of 10 quid it seems like excessive effort to go hunting.
quote:I agree, likely to cost more than just ordering it new. but where's the fun in that...
Originally posted by jps
... digging in skips to pull it off fridges/etc if
You could laminate it very easily out of three bits of sheet. A decent epoxy would be reasonably strong (unless very hot).
actually many fridges have 'brightwork' trims on the door pockets and shelf edges
I would try looking for poster/advertising frames, you some times get them in restaurant loos etc.
If there is a bus repair garage near you the U moulding you need is used on some wheel arches
I know I use to fit it
Graham
Ooh, I think we might have a winner! We have trim on our kitchen fridge which would suit, but I think I’ll be pushing my luck if I use that!
Any luck?
And how about sharing what you were intending it for , just so we can help more?
I have not had chance to go skip-diving yet, but I am eyeing up poster frames/etc at work based on all the suggestions...
I have made an amended version of the remote brake reservoir holder that Voucht shared plans for many years ago. It's from 2mm sheet alu, folded
at the top for rigidity, but I want to strengthen the front of it, and trim the edges, so metal (i.e. less flexible) channel seems best to do both
jobs at once. I could reinforce it with some additional alu sheet in strips, then trim the edges with rubber u-trim, but I think it will look better
all in metal.
So far it looks like this:
Brake reservoir
You can see the vertical section has bowed a bit whilst it's all been put together.
I suppose an alternative would be to rivet some L angle to the vertical, but U trim would be more compact.
[Edited on 10/11/2023 by jps]
