I have been asked if I could complete a shower installation which was started by the homeowner.
One of the shower walls is bare brick which he sealed with PVA and has then started to tile direct on the bricks.
I wouldn't have dreamed of doing this but do you think it will be OK. I don't want to carry on with this method and then be blamed if
there is a problem in the future.
John.
I reckon it would be ok but the amount of adhesive you would use would be increased and the result flatness would be much more difficult to
achieve.
Personally I'd at least skim with plaster to flat it out a bit...
Itll be ok but i would put a layer of base coat plaster (browning) on to provide a good surface to tile onto
i do a lot of tiling and i would insist on covering the brickwork up first or not do the job.
best way is to stick plasterboard on with driwall adhesive, easier to get flat and can be tiled onto straight away. should leave 4 weeks for new
plaster.
any backing plaster(browning, bonding etc.) needs skimming before tiling and plaster can carry a lot less weight of tiles than plasterboard
as its a shower it should really be tanked before tiling but customers will never pay the extra for that
[Edited on 8/2/09 by bigfoot4616]
Whats 'tanked' ?
Originally posted by MikeR
Whats 'tanked' ?
