Golf ECU chipping?
cadebytiger - 7/5/09 at 09:26 PM
I was just wondering what the general consensus is on chipping is?
Seem to remember a few good diesel results but what about the petrols?
I have a golf gti mrk4 (150hp)
Just wondering really. Thanks
Rupert
tegwin - 7/5/09 at 09:30 PM
That is all going to depend on what engine it is... is that the 2.0L or the 1.8T GTI?
If it is the 1.8T then yes... a well chosen chip should take you up to 180hp... a better chip with a bigger intercooler and some fiddling would take you to around 220...
McLannahan - 7/5/09 at 09:30 PM
I had my old AUM engine'd MK4 Golf turbo (2001) chipped by Revo.
Made a fantastic difference- completely transformed the car. Economy went up went I drove it sensibly. Clutch was fine - held up well.
Traction control could sometimes be a little brutal and front wheels would thump under extreme acceleration.
I was very happy with mine, made it what the GTi should have been in the MK4!
bassett - 7/5/09 at 09:31 PM
Definitely do it. Reliability wise it puts a minor additional strain through increased boost pressure and optimised running but no one has problems. It isnt old school style chipping, ecu is flashed through diagnostics plug so is completely reversible and almost undetectable from vw equipment. Gains should be 40bhp and more than that in torque maybe more if K03s turbo. Will be remaping my K04 turbo'd leon soon at AMD Essex for about 260-275hbhp. Worth while (if you havent already) getting a forge dump valve 007p, cotton/foam panel filter and uprated turbo intake pipe for optimal running with the map as although stage one maps are generic they have some adjustability.
Adam
[Edited on 7/5/09 by bassett]
McLannahan - 7/5/09 at 09:35 PM
All Mk4's were 1.8t - Mk5 was the 2.0.
Early engines (pre 2000) will chip to about 180/190 later engines will chip to 210 ish. Later engines had better turbos and more tuneability.
Having said that the early engines (AGU I think) can take a good hammering and are often the engine transplant of choice into other VAG's.
Mine was chipped for 220. I take that with a big pinch of salt but was noticeably faster and more powerful than similar cars and engines.
Mad Dave - 7/5/09 at 09:35 PM
Have a chat with my mate Simon at CCCTech
stevem2727 - 7/5/09 at 09:35 PM
I have a 54 plated skoda octavia vrs which i had chipped and it made a huge difference,much more responsive.Only downfall was the fuel consumption took a big hit even when being light on the throttle.
skydivepaul - 8/5/09 at 12:13 AM
i can recommend jabbasport they are experts on the VAG 1.8 and 2.o turbo engines. they did a custom remap on my audi 1.8T. i asked what they could do and they replied how much do you want!!!! i asked for as much power without hurting the fuel consumption. i got 228BHP with 32mpg on a 52 plate A6. not the cheapest place at £500 but they had it on the rollers for 3 hours. top result.
cadebytiger - 8/5/09 at 07:13 AM
Thank guys!
What does this do to your insurance? I'm assuming you have to tell them and I cannot imagine they would look fondly on them!
cadebytiger - 11/5/09 at 09:43 AM
I'm interested in the the Revo ECU remap. It seems quite expensive at £400 for a bit of software!
Does anyone know of anyway to get this software in a locost fashion??
Thanks for all the advice
McLannahan - 11/5/09 at 08:24 PM
Hi - Revo is one of the more expensive but there's plenty of cheaper alternatives. This forum has loads of advice on it and it's well worth asking others what they recommend for your engine type. If you don't know which one it is it'll tell you on the white sticker under the boot carpet.
http://uk-mkivs.net/
Chipped UK are cheaper than many and have quite good reviews and support too. They're offering a £250 all in service at the moment according to this post...
http://uk-mkivs.net/forums/t/258306.aspx
Don't try to skimp too much to save money on this - I'd stick with the forum recommendations. My clutch was fine afer my mapping but it's not uncommon for people to go through what was left on their old clutch with all the new power the map releases!
Hope that helps a little
