recently picked up a nice original Corsa for daughter to drive.
No history of cambelt change though, so set to it today.
Good advice and "feel" suggested a new water pump too.
Took about an hour to get all the bits off, and another 3 hours to NOT get the water pump off.
This is what it looks like now
Any ideas what to do to it next.
As can be seen, I've smashed the nose off and chisled it to death, the flange is almost gone, but the inner body is still siezed in the hole
I've even dropped the weight of the car on it to no avail?
Clearance is an issue , but there's no way I'me taking the engine out to do it
B'stard corsa Pump
[Edited on 9/5/09 by ReMan]
isnt there a metal pipe going into the back of the pump that you can take off?
vinegar
If its alloy water pump that will get rid of the corision.
Blow torch, lots of heat will pop that out
will the vinegar not corrode the alloy?
did you go for a drink last night at the sharnford arms?
No, no plans made
might be worth organising a bi-monthly beer meet!
A good soaking in penetrating oil might help ? I have had a few to change over the years and all of them have been tight, I normally use a BIG drift and hammer on the pulley to shift them. It looks like you have tried to lever the pump from the block as the shaft still looks straight? Hit the end of the shaft at right angles to it a few times , that should get it out. I always put a bit of Copperslip on the body of the pump before fitting.
Some one was almost there with the answer.
At the back of the pump housing is a water hose. Remove hose.
Insert appropriate sized drift in through tube at the back off the pump housing.
HIT drift heavily and HARD with suitably LARGE sze of hammer.
Yes I know space is at a premium, but......
Oh and replacement tubes are available from the dealers (They fit from the pump side of the housing), incase you damage the tube. I know cos I've
been there & done that.
Hope this helps.
[Edited on 10/5/09 by jollygreengiant]
Oh and replacement tubes are available from the dealers (They fit from the pump side of the housing), incase you damage the tube. I know cos I've been there & done that.
Hope this helps.
The B******D is out!!!!!!!!!!
Did vinegar and heat, early this morning, not a glimmer.
Stripped all the bits out from behind the engine then with a 12" + 6" socket extensions. then a long crowbar as a drift tyo get the right
angle of attack , many many beatings with a mallet and it finally came out.
Thanks JGG prawnabie and paul, it certainly not easy, a last resort, but the hour it took me making room was worth it in this case as it was not
playing nicely.
Not sure how the metal tube/sleeve /hose connector fits in if it wais damaged, is it a screw or a push fit?
Just got to 2work out where all the bits i took of yesterday go back now!
[Edited on 10/5/09 by ReMan]
Stripped all the bits out from behind the engine then with a 12" + 6" socket extensions. then a long crowbar as a drift tyo get the right angle of attack , many many beatings with a mallet and it finally came out.
Thanks JGG prawnabie and paul, it certainly not easy, a last resort, but the hour it took me making room was worth it in this case as it was not playing nicely.
LCB answers a question before I've even asked it.
Yesterday I established that the water is not circulating in the Corsa my mother uses, she does so little distance she never gets it properly hot.
Normally I have a mate who owns an independant garage work on the plastic cars but thought I might have a look myself at the waterpump on the Corsa
today, not any more though....
Fred W B
I've got one on the yard now waiting for a head gasket so I think I may as well do this and the belt at the same time, it may save some grief in the near future for someone. Did you have any trouble getting the crank pulley bolt out or removing the pulley itself ?
Normally I have a mate who owns an independant garage work on the plastic cars but thought I might have a look myself at the waterpump on the Corsa today, not any more though....
Yest the thermostat is also a definate maybe at the same time as the belt and pump.
