I drove my Saxo for the first time on Sunday - first drive was to the start line for first practice on a hill climb!
There's a rumbling from the front end that speeds up with road speed but doesn't seem to vary on lock. Before I strip it all apart what do
you guys and gals think? First guess is wheel bearing, second CV joint.
I'd post on the Saxo forum but I don't speak the language and I don't think you're allowed to post unless it's about lowering
your car or disconnecting the ABS ...... :-)
Might be worth checking the wheels are in balance? Then it would most probobly be a wheel bearing like you say
You could ask Paul Tigerb6, he's had loads of probs with his own saxo!
He's not posted on here for a few days, which is unlike him, but he's still logging on as usual I think...
First check for a loose wheel !
But by far most likely cause is wheel bearing
[Edited on 13/5/09 by britishtrident]
Or the wear limit bits in the tyre treads...
Hugh
I agree,
I had a rumble on my 106 and it was the wheel bearing, they aren't expensive but they are a pain in the a*se to change. Hope you get it sorted
without too many problems.
Thanks guys - wheel bearing change seems to require taking the strut off!
It's gone to have the rear cage welded up so I'll do it on the weekend hopefully. Can't wait. :-(
It's funny, I keep getting a really loud rumbling noise when I'm out in my new convertable, maybe you guys could look at this picture?
Chris
could be cos you have the suspension a bit stiff Chris?
Could be, it only happens at high speed though - anything over 1.5mph
So that's how they make plywood.
Paul G
That guy in the back, has proper got the horn! (Not surprised really - he is stood next to a porn star in maid's outfit!)
