VAG Specialists in or around Chester?
McLannahan - 12/7/09 at 11:30 AM
My Father has an issue with his 04 TDi Passat and doesn't want to spend silly money having VAGCOM plugged in at the dealer to find out it's a pennies part (hopefully!)
Can anyone recommend a VAG specialist near or in Chester that he could take his Passat to? It's displaying the emissions indicator on the dash computer every once in a while but I'm hoping the cause will be logged!
Thanks all
Michael
mookaloid - 12/7/09 at 11:48 AM
You can get plug in ODBII readers for little money or most independants will be able to read the codes I would think.
bassett - 12/7/09 at 11:56 AM
awesome gti? i know its up north but unsure where
deezee - 12/7/09 at 12:49 PM
There is an Audi Motorsport place in Ellesmere Port called RennTech. My boss has taken his diesel A4 there a couple of times. There is also Central VW Audi behind B&Q in Ellesmere Port.
Russell - 12/7/09 at 12:54 PM
Depends which side of Chester you want to travel to. There's Wilsons in Rhuddlan (near Rhyl), which is about 1/2 hour's drive away from the west side of Chester, not far off the A55. They've been doing VW's for ever and ever.
pgtips - 12/7/09 at 03:49 PM
Thanks all
Michael
Can't help you ref a dealer sorry.
What kind of issues has he got with his car?
zilspeed - 12/7/09 at 05:43 PM
Sticky EGR valve is a likely cause.
I plugged VAG COM into a workmate's Passat TDI with an emmissions light coming on and that was / is the problem.
Giving it a kicking doesn't do any real good incidentally.
McLannahan - 12/7/09 at 08:14 PM
Thanks everyone - I'll pass that all on to him. Thanks too for possible solutions - valve sounds quite likely!
PG - Every once in a while the "Check Emissions" is displayed on the FIS on the dash. It's not a serious problem but annoying. Nothing else seems untowards, it's just that his local garage doesn't have the kit to diagnose.
