Guys
I'm off to NZ and Aus on Monday for work so will spend 60 hours on a plane in the next week! I had a colleague who used to travel with me and he
was my 'pusher' for some great sleeping tablets which contained the bodies own sleep hormone. Problem is I can't get hold of him and I
don't know what they are called and where to buy them from.
Any ideas?
Edited to add below;
So - I revise my original question, what over the counter products available in the UK work well as a sleep aid when flying?
[Edited on 17/11/09 by carpmart]
alchohol.
nah i think it may be valium your after, its got a bit of a kick. i think you have to be perscribed it these days though, or it may even be illegal.
Melatonin???
melatonin is the hormone youre after, should be marketed as such too.
damn you scootz..
[Edited on 17/11/09 by cd.thomson]
Originally posted by scootz
Melatonin???
any good health shops will probably stock it.
ETA - slightly dubious about its ability to do anything though, considering the fact that ingested hormones are pretty rapidly chopped to pieces by
proteases hence why you cant take an insulin pill, you have to inject it.
Well the Cochrane review says it works here
I know you can get is prescribed by your GP, but you may be able to get it over the counter - I'd ask your local pharmacist, they are usually
very knowledgeable and helpful.
Chris
Craig - best to check the evidence before being 'dubious' !! It may be able to survive oral administration as its quite a small molecule
- whatever, it works, but needs to be taken at the right time. (as link)
[Edited on 17/11/09 by chrsgrain]
id just started reading that! I take it back, it appears to avoid the normal digestive route of proteins by some sciencey magic
ETA - interestingly it works well in combination with those "wake up" lights too if you have one handy
I have real difficutly sleeping about every 6 weeks for some reason. I have 2 - 3 nights on the trot where I'll be lucky if I get 2 hours. I take Nytol one a night for 3 or 4 nights straight which knocks me out and then I'm right again for another 6 weeks.
You brain interprets daylight and then your body produces melatonin when it gets dark. This makes you sleepy.
We buy ours in the states to make us sleep on the way home.
I don't think you can buy them legally in the UK. Its not that they are un-safe, just not tested here.
Melatonin production on nightshifts is what messes you up and can lead to things like weight gain and high blood pressure......thats my excuse
anyway!
So, after extensive searching, I think that I'm stuffed on this one as I need to order from outside the UK and I'm out of time to get them
before this trip.
I know you can get is prescribed by your GP, but you may be able to get it over the counter - I'd ask your local pharmacist, they are usually very knowledgeable and helpful.
If you can get to your GP, they will be able to prescribe it (ETA - thanks Ben, didn't know that and don't have a BNF with me at the
moment); alternatively they might be willing to prescribe you some zopiclone which is good for resynching your sleep patterns....
Over the counter meds are a bit rubbish and usually just snake oil / placebo for this sort of thing... no doubt someone will be along in a minute to
say this or that works for them, but there won't be any proper evidence!!!
Chris
If you can get to your GP, they will be able to prescribe it (ETA - thanks Ben, didn't know that and don't have a BNF with me at the moment); alternatively they might be willing to prescribe you some zopiclone which is good for resynching your sleep patterns....
Over the counter meds are a bit rubbish and usually just snake oil / placebo for this sort of thing... no doubt someone will be along in a minute to say this or that works for them, but there won't be any proper evidence!!!
Chris
I always just go for a big night out the night before longhaul flights, then go to sleep when i get on the plane
works a treat every time
Melatonin works in that it helps you drop off to sleep but dosen't make you drowsy and there is almost 100% consensus that it is safe but the EU
banned it and a whole load of other products because no company is willing to pay for officially testing it.
Some people report 5-HTP which is sold by Holland and Barret also helps you drop off.
Some hayfever products (the one that aren't marked "non-drowsy" ) will help sleep but slight drowsiness can last for 24 hours.
With flights to Oz the flight out isn't that bad unless you have a load of noisy kids near your seat but, the return is the killer.
PS I would recommend you don't fly by Garuda
I'd also reconmend you're not 6'3" with long legs on any flight - i've yet to be able to fall asleep
(interesting how many pharmacists we've got on here!)
I personally use 6-9 mg of melatonin and 50-75mg of nytol* fairly regularly to sleep.
I find separately neither work on me, but together it works very nicely, but as mentioned, usually have to buy from overseas, for which I like
www.drugstore.com and friends who travel a lot.
*actually Diphenhydramine, it's gettable OTC in the US in generic allergy meds, cheap as chips. not sure about here.
Night Nurse?
The promethazine in the night nurse capsules is a type of medicine called a sedating antihistamine. It enters the brain in sufficient quantities to
cause drowsiness, and this sedative effect may also help suppress a cough.
Personally I choose a subtle infusion of barley and hops with homeopathic levels of S. cerevisiae. Shed loads of the stuff.
See thats where I'm different, I prefer following the doctors advice to get 5 portions of fruit or veg inside me. So i start with apple, move to
pear, then strawberry, then mixed berries and if i'm lucky pineapple.
Oh the veg, errrm ....... ah heck, who cares after that much fruit.
