was just looking on youtube and found this
water mania
we have the 87k dynamic waterjet....
maybe i should do this to my bosses laptop?????
is it really just water?
I understood, and it may be wrong, that there water is mixed with fine abrasive whcih does the cutting/grinding.
it has a mixture of garnet @80mesh fed through a metering disk, but at 87,000psi the water only will cut ali up to 4mm and woods, paper and
textiles.....
and body parts too....
[Edited on 11/3/10 by boggle]
Well it cut all the ceilings out of my sisters house, having had 64000 lts pas through a burst pipe in the loft during the cold snap over Christmas
I wonder if you could sharpen a piece of ice to cut your wrists? will leave the polize puzzled looking for the weapon.
any volunteers?
ive not tried cutting ice.....
the water is pretty warm as it leaved the mixing tube so not sure if it would work??
you could just lay someone up on there and pierce holes in them for fun???
therapy?
a band from back in the day...loved the album trouble gum....
Perfectly correct, a fine garnet mixed with water at 65000 psi through a .75mm nozzle.
We have cut mobile phones in half
Will cut virtually anything apart from toughened glass, it just shatters.
Any metal, plastic, stone, ceramics ordinary glass etc etc
cheers
are you using a 10/30 setup??
we have 15/40 on the 87000...have you tried diamond orrifaces over ruby yet??
cheers
i dont know about sharpening it to cut your wrist, but you could certainly make a spike from ice, like an icicle, find a soft area to insert it with enough force could prove lethal
... it can cut my toes!
Remember working as a labourer during the school hols many years ago. Thought it would be an idea to clean the toe-caps of my wellies using the
powerwasher I was playing with... punched a hole straight through the rubber and sliced my big toe wide open!
