....... removing the bearings in my front wheel (note the carbon fibre goodness
Using a length of 8 mm studding, different diameter washers, a socket I made a puller to pull out the central tube and bearing, and then the other
bearing.
bearings are on order but does anyone know where I can get 6704 ceramic bearings?
photo shows the different bits and pieces used.
